MussyMurdock
Winbox to EVE-NG GCP
Fri Mar 20, 2020 11:20 am
Hello everyone,
As shown in the subject, I was wondering if it is possible to configure Mikrotik RouterOS inside my EVE-NG which is hosted on my Google Cloud Platform, using Winbox in my local PC. The standard configuration for the locally installed EVE-NG allows me to connect my PC network to the virtualized network, but since my EVE-NG is now on the cloud, is it possible to connect the RouterOS to my PC Winbox for easier configuration?
Thank you
GuJack20
Trainer
Trainer
Re: Winbox to EVE-NG GCP
Sun Mar 22, 2020 11:16 am
I haven't ever used Google Cloud platform but it should be possible as soon as you put a Public IP to you CHR, and connect via winbox to that IP.
If not, maybe the cloud give you the possibility to VPN to it, and then you can login in your router via a private IP, or if it is a bridged VPN, via mac-winbox.
--Do you remember that guy who gave up? Neither does anybody else!
Users browsing this forum: No registered users and 4 guests
