SergANT
Mikrotik CHR speed performance problem on VMware ESXi 6.7
Fri Apr 17, 2020 4:45 pm
Hello!
I have a problem with CHR performance on ESXi.
I have:
1. CHR 6.46.5. (unlim trial) (4vCPU + 4 GB)
2. VMware vCenter Server 6.7.0.43000 (15976714)
3. VMware ESXi (VMware ESXi, 6.7.0, 15160138).
4. Cluster from 2 node on 2xXeon CPU E5645 @ 2.40GHz
5. DSwitch (6.6.0).
6. VMXNET3
Test 1
There is a VLAN100 on DSwitch. There are CHR1 (10.1.10.11) and CHR2 (10.1.10.12). Everything is at L2 level. Both CHRs on the one ESXi host.
On ESXi-node01 VLAN100 (CHR1 (10.1.10.11) <--------> CHR2 (10.1.10.12)).
Start Tools / Bandwidth Test:
1. Use TCP / Both = Tx / Rx 2.7 Gbps / 2.7 Gbps
2. Use TCP / receive = Tx / Rx 0 bps / 6.4 Gbps
3. Use TCP / send = Tx / Rx 6.4 Gbps / 0 bps
Test 2
Debain 10 x64 + iperf3
There is a VLAN100 on DSwitch. There are Debian1 (10.1.10.101) <-------> Debian2 (10.1.10.102). Everything is at L2 level. Both Debian on the one ESXi host.
I see 17 Gbps.
And I do not understand why it happend, please help me.
Zacharias
Re: Mikrotik CHR speed performance problem on VMware ESXi 6.7
Fri Apr 17, 2020 7:06 pm
If your problem is the Speed difference 6Gbps vs 17 Gbps, i can only tell you that iperf is a better, if not the best, way to test your actual bandwidth...
Using Bandwidth test from mikrotik to mikrotik uses the CPU and that can,and will, dicrease performance...
So please check during your Bandwidth test from CHR to CHR and let us know about the CPU usage...
The best way however from RouterOS to RouterOS speedtest would be to use the Traffic generator...
Users browsing this forum: No registered users and 8 guests
