jondavy
BUG: Bridge not work with MTU=1500
Thu Aug 20, 2020 2:54 am
I work at an ISP I have a network with many QinQ VLANs because we have many services in place.
I recently migrated from a CCR to CHR,
however when I need to pass packets with a size of 1500 with vlans within a vlan within the bridge it does not pass if the packet is 1500, it does not happen when I place the vlans within ether1 directly without a bridge, but I need the bridges for other operations
I made a laboratory to reproduce the problem, I will pass the script from a CHR and RB2011
obs: the proxmox has jumboframe active and working
script to reproduce the problem:
script in RB2011:
/interface bridge add name=bridge1
/interface vlan
add interface=bridge1 name=VLAN1 use-service-tag=yes vlan-id=1
add interface=VLAN1 name=VLAN2 use-service-tag=yes vlan-id=2
/interface bridge port add bridge=bridge1 interface=ether1
/ip address add address=192.168.1.2/24 interface=VLAN2
CHR script that doesn't work:
add name=bridge1
/interface vlan
/ip address add address=192.168.1.1/24 interface=VLAN2
/ping 192.168.1.1 size=1500
CHR script that works:
/interface vlan
add interface=ether1 name=VLAN1 use-service-tag=yes vlan-id=1
I know the answer will be: so use it without a bridge, but I need them to bridge other interfaces
vecernik87
Forum Veteran
Forum Veteran
Re: bug: Bridge not work with MTU>1500
Thu Aug 20, 2020 3:35 am
Can you please test with smaller packets as well? Quite a while ago, I encountered similar issue, where VLAN-tagged packets were not passing through the bridge in CHR but everything worked fine when I bound VLAN to an ethernet interface. All details here: viewtopic.php?f=15&t=144744
If it does not work for you even with smaller packets, it is a proof the proxmox is suffering from the same issue as hyperV where I encountered this bug and it is not about size, but about VLAN and bridge... Since then, I switched CHR to an ESXi and it works fine now.
Just to make sure, I tested your situation with my live CHR on ESXi (sorry, no lab equipment ATM) and I can easily send large (8500) packets through VLAN which is assigned to the bridge.
So it is definitely NOT global bug.
jondavy
Fri Aug 21, 2020 7:07 pm
yes, with smaller packet 50 works, this fails only when i need to ping in vlan inside vlan with mtu1500
Users browsing this forum: No registered users and 7 guests
