Veria
Hetzner CHR issue
Tue Nov 03, 2020 10:24 am
Hello guys,
I tried to install CHR on the Hetzner cloud, based on https://wiki.mikrotik.com/wiki/Manual:CHR_Hetzner
but I get no hard drive found after reboot.
I tried many different versions with no success.
How can I fix this issue?
kasparskr
Re: Hetzner CHR issue
Tue Nov 03, 2020 3:46 pm
thank you for reaching out to us. We just tried with the newest stable version 6.47.7 (https://download.mikrotik.com/routeros/ ... .7.img.zip) and the above mentioned Hetzner manual and CX11 cloud VM and it worked as expected. Please try again.
Veria
Tue Nov 03, 2020 7:52 pm
Thanks for your reply,
I attached my steps and results.
Is there any mistake by me?
xvo
Tue Nov 03, 2020 7:58 pm
Try of=/dev/vda
If I remember correctly that helped me with Aruba Cloud.
Veria
Tue Nov 03, 2020 8:16 pm
Try of=/dev/vda
My disk located at /dev/sda
However, I tried vda but didn't work.
xvo
Tue Nov 03, 2020 10:42 pm
Ok. Short googling tells that you need forced reboot at the end of procedure, not the "regular" one:
echo 1 > /proc/sys/kernel/sysrq
echo b > /proc/sysrq-trigger
From here (in Russian).
Veria
Tue Nov 03, 2020 11:30 pm
the same result, it can't detect the disk.
Also, I tried the power cycle from the panel.
kasparskr
Wed Nov 04, 2020 10:25 am
RouterOS v6 kernel does not support AMD EPYC CPU's, please use CX instances (Intel Xeon based ones), instead of CPX instances which are using AMD EPYC
You can use v7 beta with the CPX instances:
Veria
Sat Nov 07, 2020 10:18 am
It didn't work with CX instances too...
Veria
Sun Nov 08, 2020 11:26 pm
This is V7 beta.
Did you try V6?
Users browsing this forum: No registered users and 12 guests
