mikruser
Why RouterOS CHR and x86 use the same distribution package?
Thu Dec 10, 2020 6:38 pm
do not ask me why it is necessary.
elbob2002
Re: Why RouterOS CHR and x86 use the same distribution package?
Sat Dec 12, 2020 9:50 am
Because they use the same architecture.
RB3011UiAS, RB750GR3, CRS328-24P-4S+, CRS125-24G-1S, CRS125-24G-1S-2HnD, 8 x CHR
mikruser
Sun Dec 13, 2020 2:03 pm
but distributions cannot be the same:
CHR should contain only virtual device drivers and VMware tools.
x86 should contain a large number of real device drivers.
Sob
Sun Dec 13, 2020 7:20 pm
I would ask why, but I know you don't like that question. It's just a little bit of useless code in both versions. Unlike with RBs, there's no "16MB flash problem" with CHR or x86, so who cares.
Excessive quoting is useless and annoying. If you use it, please consider if you could do without it.
elbob2002
Mon Dec 14, 2020 12:29 pm
CHRs need the same drivers as the x86 versions because not all CHR installations will use vNICs. Some will use PCI Passthrough devices to make the physical NIC available to the VM.Likewise USB
r00t
Mon Dec 14, 2020 2:12 pm
So this means only difference is that with native ROS license you can use wireless package otherwise it's same as CHR ?
I can confirm routeros-7.1beta3.npk package contains all normal wireless drivers, thankfully they are still present.
Users browsing this forum: No registered users and 4 guests
