glibao
Proxmox not interface
Fri Feb 05, 2021 2:24 am
Hello, I have virtualized CHR directly with the official Mikrotik image, everything is fine but when I go to put the ip to the interface, there are no interfaces, I have searched and it seems that everything is fine, do you know what it can be? attached image. Thank you
pacmen
Re: Proxmox not interface
Fri Feb 05, 2021 9:04 am
It maybe related to the way you tried to attach your interafaces to the machine itself?
Can you also include a picture of the machine HW?.
you need to take in mind that not all of the network virtualization type is supported by the CHR.
personally i will try to do it myself.
jprietove
Trainer
Trainer
Fri Feb 05, 2021 1:31 pm
Try this:
/interface print
instead of
/interface list print
pacmen
Sun Feb 07, 2021 7:09 am
So i've worked on it this morning and setup an CHR on proxmox to check your issue.
And i found that if im adding the interfaces while the CHR is running i can't see my added interfaces, but if i reboot the CHR the interfaces are loaded correctly.
Note that i was added 3 type of interfaces
So you just can't add interfaces while the CHR is running.
Users browsing this forum: No registered users and 11 guests
