jinkt
xen on alix 1d
Wed Jul 22, 2009 10:57 pm
hi
is it possible to run xen on this http://www.pcengines.ch/alix1d.htm ?
routeros instalation is ok, but after installation of xen package, router doesn't boot
it reboots after loading image
is problem with cpu on this board ?
thanks
gcakici
Re: xen on alix 1d
Fri Nov 13, 2009 2:40 pm
Any luck on that?
janisk
Re: xen on alix 1d
Fri Nov 20, 2009 3:46 pm
what version are you trying to boot there, can you try something older, like 3.13 3.20?
also, if CPU supports virtualization i would strongly suggest to use KVM instead.
gcakici
Re: xen on alix 1d
Fri Nov 20, 2009 9:11 pm
Version is 3.22 and cpu does not support kvm. I've tried linux and xen on the same board it worked. I think some compile options may prevent Mikrotik's Xen kernel to boot on that.
janisk
Re: xen on alix 1d
Mon Nov 23, 2009 9:45 am
if you installed xen package and it booted up, that means that xen kernel is sarting correctly problem is with memory allocation. To create and run guest DomU, you need to reduce memory available to Dom0, and that is what is not working. Try some older version please.
Users browsing this forum: No registered users and 2 guests
