canopa
Backup Routerboard with Metarouter
Wed Sep 02, 2009 1:32 pm
Hi there,
I would like to ask you how to back up full image of Metarouter running on RB433!? If I carry out classically backup and restore in routerboard, the system is transferred but without image. Is there some another way how to backup routers including Metarouter?In metarouter run OpenWRT
P.
janisk
Re: Backup Routerboard with Metarouter
Fri Oct 16, 2009 3:34 pm
unfortunately you have to backup image files separately. Backup does not restore /file section.
ccr
Wed Dec 02, 2009 4:31 pm
Yes; you have to backup the main routerboard and then each meta router. In some cases backups have been a major problem for me on Meta Router. When memory size was set to 64 backups did not work correctly. Then you have to install the backups in the correct order.
Users browsing this forum: No registered users and 2 guests
