xezen
Long time Member
Long time Member
metarouter X86
Thu Oct 08, 2009 5:38 pm
any ideas when metarouter will work on x86 platform?
If i dont No Ask someone That Does!
changeip
Re: metarouter X86
Thu Oct 08, 2009 6:35 pm
metarouter is for the MIPs platform I believe. x86 should use Xen, only if it were more stable : )
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
csickles
Re: metarouter X86
Sat Oct 10, 2009 9:20 am
I havent had any luck..
Just cant find a "compatible" system yet.... :?
Things that make you go "Hmmmmmmmm"...
Craig
janisk
Re: metarouter X86
Thu Oct 15, 2009 11:35 am
if your router have CPU with virtualization support - try using KVM
edit: corrected typo
xezen
Long time Member
Long time Member
Re: metarouter X86
Fri Oct 16, 2009 8:35 am
dont get this PCU KVM were are th options
dssmiktik
Forum Veteran
Forum Veteran
Re: metarouter X86
Sat Oct 17, 2009 1:19 am
Instructions on KVM on Mikrotik can be found here:
http://wiki.mikrotik.com/wiki/Kvm
Doug
xezen
Long time Member
Long time Member
Re: metarouter X86
Sat Oct 17, 2009 9:53 am
thanks for the link
xezen
Long time Member
Long time Member
Re: metarouter X86
Mon Jul 26, 2010 10:54 pm
cpu dont support it how do i know if its supported?
janisk
Re: metarouter X86
Thu Aug 05, 2010 12:04 pm
you can check here if your cpu supports or does not virtualization:
http://en.wikipedia.org/wiki/X86_virtualization (that link is in KVM manual also on MT wiki)
also, check if you have enabled virtualization in PC's BIOS. Some motherboards require newer BIOS version for that to work correctly.
Also, someone mentioned XEN - it was discontinued at version 4.4 and is not recommended for use and should be avoided.
KVM configuration can only be done through CLI and for that matter also API, but there are no such possibility from winbox and webfig at the moment.
Users browsing this forum: No registered users and 7 guests
