soho
Export Image from MetaRouter
Tue Oct 20, 2009 3:56 pm
hi all,
how to export image from VM in MetaRouter?
enderx
Re: Export Image from MetaRouter
Tue Oct 20, 2009 7:14 pm
This is how I've been doing it for openwrt images.. not a very good way.. but its all I've got.
install tar
opkg install tar
create image
cd /
tar zcvf /tmp/newimage.tgz --exclude proc/\* --exclude sys/\* --exclude tmp/\* .
scp /tmp/newimage.tgz user@anotherhost:/tmp/.
put newimage.tgz on the mikrotik router you'd like to create a metarouter on, and "import" it.
hope that helps..
Sam.
soho
Tue Oct 20, 2009 10:41 pm
install tar
opkg install tar
create image
cd /
hope that helps..
Sam.
hi Sam.
thankfull for your help.
Until Mikrotikls not create an option for this, his way is perfect.
jberen
Trainer
Trainer
Mon Sep 23, 2013 3:54 am
Very Good Job
Congratulations!!
Javier
thesoundkid
Thu Oct 10, 2013 3:04 am
I was looking to do this and worked out how without updating tar.
cd /
ls /tmp/* /proc/* /sys/* > /tmp/exclude
 tar zcvf /tmp/newimage.tgz -X /tmp/exclude  .
payday
Fri Oct 11, 2013 9:14 pm
It is easier to create file with dirs only. My exclude file looks like this:
./proc/*
./sys/*
./tmp/*
This works very well with built-in tar command (from BusyBox).
thesoundkid
Thu Oct 31, 2013 12:54 am
Thanks for that info payday.
I had trouble getting wildcards to work but that exclude file works perfect.
What Openwrt images and repo are you using out of interest?
seems like metarouter is rather unsupported by both MT and OpenWrt.
payday
Tue Dec 31, 2013 7:13 pm
I use images from here:
http://openwrt.wk.cz/
NathanA
Forum Veteran
Forum Veteran
Wed Jan 08, 2014 2:07 am
payday, people in this thread are talking about how to make a backup copy/image from a router of a running OpenWRT MetaROUTER instance that has been modified. They aren't asking where to download stock images from.
-- Nathan
payday
Wed Jan 08, 2014 10:20 pm
It was an answer to this question:
You are funny, Nathan :)
NathanA
Forum Veteran
Forum Veteran
Thu Jan 09, 2014 4:38 am
It was an answer to this question: [snip]
Oh, man...how embarrassing. My bad. I apparently skimmed over that, and you didn't quote it in your response, so at first glance it looked like it totally came from left field, as if somebody had necro'd a months-old thread that they hadn't previously been participating in by posting something completely unrelated to it.
My apologies.
-- Nathan
payday
Thu Jan 09, 2014 7:05 pm
...you didn't quote it in your response...
You are right. Excuse me. Next time I will do it. :)
ppaulojr
Thu Jan 23, 2014 4:36 pm
install tar
opkg install tar
create image
cd /
hope that helps..
Sam.
I did this procedure and a funny thing happened. The metarouter created is a a RouterOS
MikroTik 6.7
MikroTik Login:
What could be wrong?
Users browsing this forum: No registered users and 6 guests
