lopezandres
XEN to KVM
Tue Dec 15, 2009 3:03 pm
I cann't setup KVM on my PC-RouterOS:
Actually I'm using XEN for routeros image and wanto to migrate it to KVM, but I allaways get "status=unsupported-cpu".
I have enabled at BIOS the VT option.
Someone can help me please.
Can XEN and KVM running at the same time?
> > I'm using a PC with
> > INTEL MotherBoard DG31PR
> > CPU INTEL E8400
> > 2GB RAM
> > [lopezandres@RT001] /kvm> print
> > Flags: X - disabled
> > 0 ;;; cantv kvm guest
> > disk-images=hda:cantv.img initrd="" kernel=""
> > kernel-cmdline="console=ttyS0" name="cantv" cpu-count=2
> > memory=256MiB
> > snapshot=no vnc-server=0.0.0.0:0 state=unsupported-cpu
> > [lopezandres@RT001] /system license> print
> > software-id: "XXXX-XXXX"
> > upgradable-to: v5.x
> > nlevel: 5
> > features:
> > [lopezandres@RT001] /system resource> print
> > uptime: 30m50s
> > version: "4.3"
> > free-memory: 1739444kB
> > total-memory: 1790208kB
> > cpu: "Intel(R)"
> > cpu-count: 2
> > cpu-frequency: 3000MHz
> > cpu-load: 0
> > free-hdd-space: 132009640kB
> > total-hdd-space: 153818816kB
> > write-sect-since-reboot: 4941
> > write-sect-total: 4941
> > architecture-name: "x86"
> > board-name: "x86"
xezen
Long time Member
Long time Member
Re: XEN to KVM
Tue Dec 15, 2009 3:12 pm
i have xen installed but when i do this
/kvm nothing
is this right how do i install or enable kvm
must i remove xen
i have x86
If i dont No Ask someone That Does!
lopezandres
Re: XEN to KVM
Tue Dec 15, 2009 5:03 pm
Thanks xezen.
So I have to unistall the XEN package and try to use KVM?
normis
Re: XEN to KVM
Wed Dec 16, 2009 8:44 am
Make sure to remove Xen first, and then check if you have VT enabled in your BIOS. VTx is needed by KVM. Your CPU supports it, but it must be enabled.
Users browsing this forum: No registered users and 6 guests
