Hi, a simple question (I hope). I'm trying to install for testing, an instance of RouterOS 4.4 running on a KVM Virtualized host (running on ProxmoxVE virtualization platform). I can boot my installer ISO image fine, select features to install (such as "minimal") - and then press "i" to install. At this point .. nothing happens .. but the keyboard is no longer responsive; there is no CPU loading nor disk activity on the VM.
I'm curious if there is a known issue with running RouterOS within a KVM virtual environment / or if there are particular settings which must be adjusted in order to make this work ?
Thanks!
Tim Chipman
Fortech I.T. Solutions
http://FortechITSolutions.ca
