colson
Files on Metarouter
Thu Feb 11, 2010 12:17 am
It is possible to load files onto a metarouter? I have tried the drag and drop technique and have also tried to ftp them on with no success.
Thanks!
Chris
janisk
Re: Files on Metarouter
Thu Feb 11, 2010 11:54 am
i have not encountered any problems with writing or reading files from RouterOS running as guest on MetaROUTER. Please check if you have not set any disk size limitations in metarouter configuration.
colson
Wed Feb 17, 2010 6:14 pm
I am using an RB-433, could this be my problem?
Also, would it be possible to run a separate hotspot in the virtual machine? This is where I discovered I could not add the .html files.
Last question, could the virtual hotspot use a virtualAP if it is in a bridge or use it directly?
Thanks,
Chris
janisk
Thu Feb 18, 2010 1:12 pm
no, check your settings, there should not be any problems.
try /metarouter print to see how much your virtual machine use disk space.
also, how much RAM does it use, and how much free RAM you have?
Users browsing this forum: No registered users and 4 guests
