coyotenq
RouterOS kernel
Tue Feb 23, 2010 8:22 pm
I'm working on a RouterBoard 433UAH. I'm trying (and with a relatively success) to run a more complex linux system on it. I know Mikrotik don 't support other software than RouterOS, but, in my case, i'm using only your hardware. I need some things that RouterOS can't do, like a NAS, and run a full webserver, mysql... etc..
Point is, i.m using an OpenWRT kernel and a OpenWRT Filesystem. But i have a problem with the kernel. I need to activate all the ETH ports (only one works actually) and the MMC controler (the MicroSD card is not recognized). The rest works fine, i have a full install of the soft i need.
If anyone can, i need the set of the kernel lastest RouterOS is using, so i can get ETHs and MMC to work.
Routerboards are great, the hard is amazing, and with some mods are really versatile. If i can get the hard full recognized, my job can be finished. If anyone are interested in this, i can post more details.
Thanks in advance.
Alejandro
normis
Re: RouterOS kernel
Wed Feb 24, 2010 10:15 am
write to support for more info on this
changeip
Re: RouterOS kernel
Wed Feb 24, 2010 6:46 pm
i am very interested in this. do you think you could get a minipci audio card working with openwrt or debian on the routerboard?
http://www.globalamericaninc.com/produc ... id=3507155
Could replace those darn expensive barrax boxes ...
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
coyotenq
Re: RouterOS kernel
Tue Mar 02, 2010 2:52 pm
@changeip: In my tests, using OpenWRT as base kernel (their patches works great with this RB, only a couple of things don't work), i get Debian mips to run on it, with all the software that works on it. OpenWRT supports USB audio... so... probably, you can use this board to your project too.
greetings,
Alejandro
csickles
Re: RouterOS kernel
Fri Mar 05, 2010 5:40 am
"Change".. what you up to ??? :) :?
Things that make you go "Hmmmmmmmm"...
Craig
Users browsing this forum: No registered users and 8 guests
