fmenard123
RouterOS Documentation
Thu Apr 15, 2010 6:48 pm
When you click on :
RouterOS Manual
It takes you to :
http://www.mikrotik.com/testdocs/ros/2.9/
Which is version 2.9
Is the documentation current ?
F.
janisk
Re: RouterOS Documentation
Fri Apr 16, 2010 8:33 am
Chupaka
Fri Apr 16, 2010 1:35 pm
yep, it's time to edit forum's head =)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
normis
Fri Apr 16, 2010 1:46 pm
done :)
Chupaka
Fri Apr 16, 2010 3:49 pm
super! and maybe remove those black dots in almost random places? =)
like
VS
janisk
Fri Apr 16, 2010 3:57 pm
fix alignment in your browser. Set it to left, instead of right as it is now
normis
Fri Apr 16, 2010 4:01 pm
This is how it's supposed to look:
Chupaka
Fri Apr 16, 2010 5:20 pm
it's okay now, thanks for fixing =)
Users browsing this forum: No registered users and 1 guest
