blackmetal
Problem with booting ros on Xen Virtual Machines
Mon Aug 16, 2010 9:04 am
i install ros on my xen virtal machine with iso file but when i want boot it it says Mising operation system,
is there any solution for this?
and also i attach screenshot of my error to this post,
janisk
Re: Problem with booting ros on Xen Virtual Machines
Wed Aug 25, 2010 3:39 pm
ISO does not know anything about XEN, so it may fail. You can try to isntall odler RouterOS and then try to boot that image with XEN package installed on RouterOS. But i would suggest you to look at KVM instead as it is more stable and you do not need to alter kernel to run in it.
wpeople
Wed Apr 13, 2011 1:26 pm
As is posted http://forum.mikrotik.com/viewtopic.php ... 88#p258688 I could install RouterOS 4.17 into Xen HVM.
Simply booted the CD, after install, shutdown the DomU, edit the config (remove cd image, and set boot to HD image) and worked
Sadly could not install 5.0 nor can upgrade
janisk
Wed Apr 13, 2011 2:33 pm
can you try to boot linux with 2.6.35 kernel?
blackmetal
Wed Apr 13, 2011 2:37 pm
the problem solve,d
thansk,
wpeople
Wed Apr 13, 2011 3:50 pm
Janisk, Debian 6.0 even have 2.6.32-5-xen only :-(
Do You have a good reason why not 2.6.32 work but 2.6.35 would? if so, i would try to make a 2.6.35-xen kernel. thanks!
janisk
Thu Apr 14, 2011 9:06 am
that -xen extension usually means that kernel have xen support in it. And that is what you want to avoid.
wpeople
Thu Apr 14, 2011 9:49 am
I don't have the point why i have to avoid xen (on Host machine).
janisk
Thu Apr 14, 2011 3:10 pm
if you where talking about host, then yes, you can try, if guest - avoid :)
XEN was once supported virtualization on x86 hardware but was replaced by KVM. And the later has become very stable lately.
wpeople
Thu Apr 14, 2011 5:05 pm
yes, host is xen.
I've upgrade Lenny to Squeeze, Xen 3.2-1 to 4.0 and works!
(kernel is stock 2.6.32-5-xen-amd64)
I mean, now i can install 5.0 and also upgrade 4.17 to 5.0!
Solved, thanks!
bobwalker
Sat Mar 23, 2013 11:45 am
the problem solve,d
thansk,
how to solve?
wpeople
Sun Mar 24, 2013 10:39 pm
Bobwalker: as you see, upgrade from lenny to squeeze (kernel 2.6.32 to 2.6.35)
Users browsing this forum: No registered users and 7 guests
