MUM Europe 2020
_Sheriff_
KVM and "unsupported pcu"
Sun Jan 09, 2011 5:40 pm
Hello.
I have a little problem.
I want to install a small Linux distributions.
In this distribution I want to run radius server, web server and many others.
But I can not install any version of Linux, all the time says "unsupported PCU"
Can someone tell me what is wrong?
If you need more information, please ask.
Waiting for your help
Skype: sheri_ff --- Configuration and administration of networks based on a MikroTik ---
ayufan
Re: KVM and "unsupported pcu"
Sun Jan 09, 2011 6:00 pm
You need processor with hardware virtualization support, eg. VT-X, AMD-V.
hAP AC, TP-Link Archer C7 v2, RB951G, RB450G, RPI2, RPI zero
_Sheriff_
Sun Jan 09, 2011 6:25 pm
that is, I can not use KVM on this machine?
I can only metarouter and OpenWRT, exactly?
Where can I find a list of processors that support virtualization?
fewi
Sun Jan 09, 2011 7:36 pm
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
janisk
Mon Jan 10, 2011 12:59 pm
there is a yet unresolved problem that somehow user is not able to run KVM on machine that supports virtualization.
But first things first - check if BIOS is as fresh as you can get, check if all the settings about virtualization is enabled in there (the BIOS) if using RC7 and not encountering the problem i described, KVM guests should work.
_Sheriff_
Tue Jan 11, 2011 5:20 pm
I have the latest Bios.
I checked, there is nothing in the BIOS on virtualization.
All the settings seem to be good.
I do not know why this happens.
Just want to install a Radius server. To avoid having to put another computer.
Users browsing this forum: No registered users and 4 guests
