Joziff
OpenWRT in metarouter
Fri Mar 04, 2011 6:35 pm
I have a problem with OpenWRT configuration on metarouter. The problem is that I dont know how to setup configs in WRT.
On my router I have interface1 as DHCP client, where my provider gives me IP & DNS, and ethers 2,3 are bridged so works as DHCP server for joined klients truth masquarade. And I need to know how I can connect host system RouterOS with OpenWRT, because Im not so good in linux.
I tried to setup it as dhcp client so I can use ping everywhere. But problem is that only on IP. If I try address it fails. Maybe problem with DNS which udhcpc start setting but it dont close.
Thx for help.
mrz
Re: OpenWRT in metarouter
Mon Mar 07, 2011 9:54 am
You will get better luck with configuration help on OpenWRT forum.
Users browsing this forum: No registered users and 1 guest
