angboontiong
How can i install linux in Routerboard...
Fri Dec 14, 2012 8:02 am
Hi, i would like to make use of the Routerboard to monitor my UPS which it come with the file for linux use [xxx.tar.gz].
is there any where i can install it.
appreciate it.
dentikhval
Re: How can i install linux in Routerboard...
Tue Mar 19, 2013 4:52 pm
If you have an APC ups then you can monitor it directly from ROS, excluding ROS 5.20(it doesn't work there). If you have another one, you should take a look in the KVM manuals. I personally have 2 UPSs from APC and both of them are monitored through ROS.
Users browsing this forum: No registered users and 1 guest
