MUM Europe 2020
waynz0r
VLAN Trunk port in KVM guest
Thu Jun 06, 2013 1:41 pm
i would like to add a 802.1q trunk port directly into a KVM guest, but i cannot make it work.
I created a bridge which contains the interface which is connected to a trunk port on my switch and the tap interface which is added to the KVM guest.
Is this scenario even possible?
Update:
Ok, my bad. I was tried to use a vlan in the KVM guest which was already defined and used on the host. Looks like it doesn't work that way.
Thanks!
W.
janisk
Re: VLAN Trunk port in KVM guest
Thu Jun 06, 2013 2:43 pm
VLANs in guest work in the same way as they do on normal router. Meaning, this configuration would not work even if it was not a virtual guest.
Users browsing this forum: No registered users and 8 guests
