MUM Europe 2020
shakal
Which virtualization used instead of VMware Workstation?
Wed Mar 26, 2014 9:07 pm
I have a Virtual PC made ​​in VMware Workstation on Windows. Which virtualization use instead vmware on linux-ubuntu 64-bit? KVM?
Robert Haľák, Inomanet s.r.o
Internet, VoIP, SMS, USSD
janisk
Re: Which virtualization used instead of VMware Workstation?
Fri Mar 28, 2014 3:41 pm
you have to check features what each VM provides and what will be the future of your guest. Then choose one that is more appropriate for your needs and future plans.
tomaskir
Trainer
Trainer
Fri Mar 28, 2014 3:43 pm
You can either use KVM, Qemu or VirtualBox.
ROS works with all of those.
Unimus - configuration management, automation and backup solution
Mass Config Push, network-wide RouterOS upgrades, and more!
WiZaRd
Tue Jul 01, 2014 5:05 pm
Hello there,
Dose anyone knows if you run MKT OS on a vmware ESXi, are there any TCP connection limits ? I have a client, running MKT OS6, on a vmware ESXi v5, the server only allows 4500 connections or so. If we get more than 4500, the server fails. It has 4 quad core CPU's 20 Gb ram and 1 TB storage.. I dont know if anyone had this problem.
Thank you.
janisk
Wed Jul 02, 2014 11:24 am
you can attempt to configure your network interface differently on your VMS host. As numbers you are calling are quite low and you would not be the first one to hit them.
Haider459
Fri Oct 31, 2014 9:45 pm
Janisk,
Can you tell us if you're working on adding support for Hyper-V? IMO, MT could do some really cool things in terms of switching and routing in the virtual network. Take a look at what Cisco is doing with their Nexus 1000v product, it is pretty amazing. I don't know if MT could ever compete at that level, but it would be a nice option for those of us running smaller data centers.
-Troy
Are you worried about Braindumps.com best of luck
janisk
Mon Nov 03, 2014 9:38 am
nothing is done regards Hyper-V.
You can try Vmware as that is the fastest known virtual environment or KVM as that is part of RouterOS
ava10helson
Mon Mar 06, 2017 9:47 am
For those who are running small data centers the MT is the best option. However, You can try Vmware as that is the fastest known virtual environment or KVM as that is part of RouterOS
tonyjohn29
Sun Jun 25, 2017 8:07 pm
VMware workstation is a good virtual machine software. But if you are looking for alternatives, then you can either use Virtual Box if you have good configuration or you can use the inbuilt Virtual machine in Windows.
thomasjack
Mon Sep 11, 2017 12:00 pm
can i join here?
skin
TomjNorthIdaho
Tue Sep 12, 2017 2:30 pm
VMware ESXi
kevinds
Wed Oct 04, 2017 8:53 pm
But which hypervisor is best? I need to share the NIC with the host as a bridge, running on a Xeon 3460.. Trying with hyper-threading disabled right now on ESXi
CPU features visible, CPU features hidden, different NIC types.
Don't care about the hypervisor's features, only care about the CHR performance.
Trying to prove network issues but CHR is being blamed. I would go bare-metal but with not being able to transfer the license to another install, since I won't have the hard drive, I don't want to go this method (that is the only thing stopping me from doing a bare-metal install).
So, which combination works best?
Steveocee
Fri Oct 06, 2017 12:01 pm
If an existing installation is being blamed as a problem then does it matter which you choose, the objective is to prove or disprove the installation on the existing machine? ESXi I have found works CHR really well once you get over creating the relevant files.
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
mbesteve
Sun Oct 15, 2017 5:59 pm
hi, i a young boy which is doing networking qnd telecommunication. I have a problem when i have virtualize my Mikrotik RouterOs on virtual box and connect it with a virtualize network every things it's going okay but i can login with winbox. It's saying "connection refuse". please need some help
steinbergs
Tue Oct 17, 2017 2:26 pm
I'm using Quemu on my Ubuntu machine to virtualize Mikrotiks for GNS3.
I shall read the manual/color]
onyegbadocu
Wed Nov 22, 2017 1:01 pm
Hello Guys,
I just joined Mikrotic forum. I have two mikrotic routers using desktop version. According to this thread,there is virtualization for Mikrotic os. This is very good.I have Esxi 6.0.
How do i get the right virtual image for mikrotic os so that i can install it on ESXI 6.0 host.
Hope to read from you guys
kevinds
Thu Nov 23, 2017 6:58 pm
Hello Guys,
Basic search..?
https://wiki.mikrotik.com/wiki/Manual:C ... stallation
Even a video
onyegbadocu
Tue Dec 05, 2017 1:35 pm
thanks for your response? what's the link to download the iso image for virtualization ?
pe1chl
Tue Dec 05, 2017 2:06 pm
Did you actually read that manual given to you by kevinds?
Because the link to the downloadpage is right in there!
mypslgate
Wed Jan 17, 2018 11:25 am
Hello, sir,
I am a new user on this forum, my friend tells me this is an awesome forum for information. You can use VirtualBox sir.
PSL
Users browsing this forum: Google [Bot] and 1 guest
