payday
Router reboots after MetaROUTER shutdown
Thu Jun 12, 2014 8:52 pm
I want to report a bug with MetaROUTER:
After shutting down MetaROUTER guest, router (host) hangs and after few seconds reboots itself. Log says: "router was rebooted without proper shutdown by watchdog timer".
Tested on two RB2011UAS-2HnD (first batch) with OpenWRT and RouterOS guests.
Tested also with new firmware (3.16) and newest RouterOS 6.15 but bug exist probably since v6.12.
Can anyone confirm this?
WonderLee
Re: Router reboots after MetaROUTER shutdown
Fri Jun 13, 2014 11:48 am
I got the same problem :(
janisk
Fri Jun 13, 2014 4:16 pm
confirmed for MIPS as a workaround for now - do not shutdown the guest. Only reason i know you would like to shutdown - use reboot instead.
payday
Fri Jun 13, 2014 7:37 pm
Thank you for answer.
I always shut down guests before router reboot (i.e. for system upgrade) to avoid file system corruption. I am not shure if it is safe to reboot host when guests are running. I guess RouterOS does not shutdown guests before reboot.
Is this bug on the list already or you want me to report it?
janisk
Mon Jun 16, 2014 9:49 am
the bug is filed anyway.
payday
Mon Jun 16, 2014 7:35 pm
Thank You :)
sergioag
Wed Aug 13, 2014 4:02 pm
I got the same problem !!!
RB2011UiAS-2HnD, Firmware 3.10, ROS 6.15
ab130kd
Tue Aug 26, 2014 11:34 am
I have the same problem on RB493G, RB750 and Metal... Please resolve because the auto reboot means for customers disservice..
NathanA
Forum Veteran
Forum Veteran
Mon Dec 01, 2014 4:06 am
This bug is still not fixed on 6.22 and can occur if you shut down or reboot the guest from the guest's console, or use the '/metarouter shut-down' and '/metarouter reboot' commands; see http://forum.mikrotik.com/viewtopic.php ... 16#p458616
-- Nathan
bajodel
Long time Member
Long time Member
Wed Feb 18, 2015 8:17 am
-- Nathan
6.27 ..still there :(
NathanA
Forum Veteran
Forum Veteran
Wed Feb 18, 2015 12:57 pm
Trust me: I know. :(
-- Nathan
rstik
Tue Feb 16, 2016 12:16 am
Happened to me with 6.34 :(
Users browsing this forum: No registered users and 1 guest
