Raffav and Normis, thank you for the clarification.
Normis, as far as the ability to move the license around between different CHR instances is concerned: Is this still valid if I were to purchase your CHR PI-10 licenses from a reseller? Does it have to be any special type of PI-10 licenses? Or does buying regular CHR PI-10 in bulk good enough.
Also - What specific steps should we have to follow for moving the currently active license key to a new CHR instance? Let's assume I had licensed CHR running and I just deleted that instance. Now I need to re-purpose that license key to a new CHR instance. The RouterOS does not allow me to change its router identity key.
best
-Amit
The CHR license I think only is possible to purchase on mikrotik site via your account also there is where you manage your CHR license
Step
Install CHR
go to system license
Select you license type,
upgrade, put you user and password used on mk site
Go to you account on mk site
There is all CHR license
You will see one CHR just added and there will be a upgrade option after you purchase
go back to you CHR
and do a renew after that you CHR is permanent activated
To move to another instance
Just install a new CHR
Put your account information
Go to the site there will be a recent CHR added with a options to transfer
you just need to choose the software I'd and transfer
Go back to CHR and do renew
Done
Edit
I would like to suggest an improvement
The transfer license is a little nasty
Since you need to find the software id,
Would be nice if the system pick the note field as reference only if empty pick software I'd
Enviado do Moto X Force
