HaPe
Softid has changed after move VHD from Virtualbox to Hyper-V
Tue Aug 25, 2015 11:43 pm
Hi, I've moved VHD file from Virtualbox to Hyper-v and soft id has changeg. But why? I haven't modified structure of disk.
In anticipation on new The Dude release.
Sob
Re: Softid has changed after move VHD from Virtualbox to Hyper-V
Wed Aug 26, 2015 6:02 pm
AFAIK soft-id depends on both disk content (some bytes somewhere from the beginning) and identification (model, etc). The latter changes with different virtualization platform.
E.g. the following VirtualBox settings supposedly allow to use originally VMware-based RouterOS disks (but I did not yet get to test it personally):
<ExtraDataItem name="VBoxInternal/Devices/piix3ide/0/Config/PrimaryMaster/FirmwareRevision" value="string:QM00001"/>
<ExtraDataItem name="VBoxInternal/Devices/piix3ide/0/Config/PrimaryMaster/ModelNumber" value="string:VMware Virtual IDE Hard Drive"/>
<ExtraDataItem name="VBoxInternal/Devices/piix3ide/0/Config/PrimaryMaster/SerialNumber" value="string:00000000000000000001"/>
I have no idea if Hyper-V allows to customize these settings.
Excessive quoting is useless and annoying. If you use it, please consider if you could do without it.
Users browsing this forum: No registered users and 5 guests
