CWDylan
POE issue port 2 v1.15
Fri May 13, 2016 11:13 pm
The issue i was hoping was fixed in the new version was unfortunately not the port poe is set to on and the status was disabled. this only every happens on port 2 and is the first time encountering this on 1.15 the uptime on the RB260GSp is 1 day 9 hours at the time of problem. I will attach screenshots for the problem and me disabling the poe and re-enabling the poe and having the access point power back on.
Problem
Turned POE out off
Turned POE out on
CWDylan
Re: POE issue port 2 v1.15
Tue May 17, 2016 6:13 pm
Seems to happen once every two to three days now.
npero
Thu May 19, 2016 12:13 pm
For me update to 1.15 resolve that problem.
Do you try to calibrate maybe help ?
CWDylan
Fri May 20, 2016 4:41 pm
Yea we always calibrate the poe ports during deployment. Doesn't really seem to make a difference.
Users browsing this forum: No registered users and 4 guests
