merlinvrn
Powering RB260GS from PoE
Wed Jul 20, 2016 12:23 pm
I just need some consulting, which hardware to buy.
It is said RB260GS (not P) switch could receive power from passive PoE 1st copper port. Which injector should I use, will RBGPOE do the work? Which power supply should I plug into injector? There is 12V power supply included with the switch, is it enough (assuming the cable will have some losses, and switch is said to work from 6V)?
I suggest Mikrotik staff to document this topic more thoroughly. Also if I am correct, it is worth adding a link to this injector to the RB260GS page into "Related products" section.
grusu
Re: Powering RB260GS from PoE
Wed Jul 20, 2016 1:03 pm
http://routerboard.com/RB260GS
You can use 9 - 30V power supply on eth 1 port. And yes,  RBGPOE do the work.
I suggest you to use power supply with larger allowable voltage value (24 - 30V) so cable losses to be as small as possible.
Anyway, 12V power supply included is quite enough to be used with POE injector RBGPOE on 1st port.
gutekpl
Mon Sep 21, 2020 4:51 pm
Hi.
And what if I will plug ETH1 of RB260 to some PoE Switch with 802.3af / 802.3at? Because of passive PoE I am afraid auto-negotiation will fail to set proper voltage? Or it will work OK?
xvo
Mon Sep 21, 2020 5:39 pm
Hi.
802.3af / 802.3at is 48V (actually can be between 36-57V), so it is too much for RB260.
Users browsing this forum: No registered users and 8 guests
