Mon Mar 13, 2017 4:59 pm
I would like to add to this, in that VLANs appear to be seriously broken on SwOS 2.0.
In previous versions of SwOS, namely 1.17, starting from a factory defaulted RB260GSP, all that was needed to allow tagged VLAN management access to the device was to assign the switch an IP address on the management subnet, then simply enter the correct VLAN ID in System -> Allow from VLAN.
On SwOS 2.0 this process does not work at all, and once carried out, access cannot be gained either through original IP (192.168.88.1) or the IP on the management subnet, be it with management VLAN tagging or without.
