blackbox100
CRS326-24G-2S+RM Bandwidth Limitation?
Fri Mar 10, 2017 1:17 am
Hi all
just received this switch, but can´t seem to find the menu where I can set the bandwidth limitation?
The description on MT site, clearly state that it should be possible
"It gives you all the basic functionality for a managed switch, plus more: allows to manage port-to-port forwarding, apply MAC filter, configure VLANs, mirror traffic, apply bandwidth limitation and even adjust some MAC and IP header fields. SFP cage supports both 1.25 Gb SFP and 10 Gb SFP+ modules."
Where can I find the settings for bandwidth limitation?
Sincerely Carsten Larsen
becs
Re: CRS326-24G-2S+RM Bandwidth Limitation?
Fri Mar 10, 2017 11:00 am
The bandwidth limiting on CSS326-24G-2S+RM will be available in the next SwOS release v2.1 which is planned very soon.
blackbox100
Fri Mar 10, 2017 5:36 pm
ok, thanks
have a nice weekend
blackbox100
Sat Mar 18, 2017 1:12 am
another question
will future SWos versions give the ability to remote control the switch either from API, telnet or other remote management other than the webgui?
Sincerely
Carsten Larsen
plankanater
Mon Aug 21, 2017 6:13 pm
I see ingress rate limiting but where can I find Egress Rate Limiting?
plankanater
Thu Aug 24, 2017 6:29 pm
So i assume these only do ingress limiting? I will be returning them I guess.
blackbox100
Wed Aug 30, 2017 5:56 pm
they say that it will come in future software versions
EchelonCA
Sat Jun 02, 2018 12:44 am
Circling back to this to see if there's been any movement as to when to expect this?
We've been looking to replace another vendor's switches with these, and the lack of egress limiting is the sticking point for whether or not we can move forward on these.
Hoping there's some dates at this point vs. "soon", otherwise it'll continue to be a pass.
2low4
Mon Nov 05, 2018 7:28 pm
What about RouterOS? Is there any way to set bandwidth?
Xsaron
Mon Apr 08, 2019 11:19 pm
Yes, you can use shaper with routeros.
http://wiki.mikrotik.com/wiki/Manual:CR ... h_Limiting
Users browsing this forum: No registered users and 7 guests
