gharris999
Switch OS 2.1 -- Warning: do not attempt RB260GSP CSS106-1G-4P-1S upgrade over POE Port
Wed Apr 19, 2017 10:12 pm
Good work guys. Just downloaded SwitchOS 2.1 from the downloads page an tried to apply it to a new RB260GSP that was running 2.0. Seemingly bricked the switch. Now I've got 2 hours of driving ahead of me to fix this. Thanks.
IntrusDave
Re: Switch OS 2.1 will brick your switch!
Wed Apr 19, 2017 11:08 pm
Congrats on being the first. Why not just put the switch into TFTP mode and upload the firmware? Not sure why you would have to drive two hours to do that. Or did you really update the firmware remotely without testing on a local device?
gharris999
Thu Apr 20, 2017 12:53 am
No, I really did do that, and I deserve the criticism. We've been having such trouble getting RB260GSs and RB260GSPs that this was our only v2 switch and it was deployed. I'm back from swapping it for one of the many "bad" RB260GSPs we've been saddled with over the past year that pass traffic & POE, but can't be logged into or configured.
The v2 RB260GSP, after the v2.1 upgrade, now exhibits the following problems:
Won't pass traffic on port 1
POE permanently disabled on the other ports.
I can talk to the switch over port 5 and I'd like to try to downgrade back to v2.0. Anyone know where I can find that firmware? It's not at https://www.mikrotik.com/download
Failing that, I'll try a reset next.
IntrusDave
Thu Apr 20, 2017 1:14 am
I'm not sure where the archive for SwitchOS is. But I would try to reset defaults and see if that helps. It sounds like the config corrupted in the upgrade.
reverged
Thu Apr 20, 2017 2:15 am
You can find most old versions of MT sw by changing the url:
https://download2.mikrotik.com/swos/2.0 ... 1s-2.0.bin
gharris999
Thu Apr 20, 2017 4:44 am
Thank you. Version 2.0 brought the switch back to life.
Just FYI: the POE outputs remained disabled on the RB260GSP (CSS106-1G-4P-1S) with SwitchOS 2.1 even after a full reset.
becs
Re: Switch OS 2.1 -- Warning: do not use on RB260GSP CSS106-1G-4P-1S
Thu Apr 20, 2017 12:22 pm
gharris999, try to repeat v2.1 upgrade once more when you have already upgraded to SwOS v2.1.
If the PoE-out problems will persist, I would recommend to report this to support@mikrotik.com
honzam
Thu Apr 20, 2017 2:59 pm
Where is changelog for SwOS 2.1?
gharris999
Re: Switch OS 2.1 -- Warning: do not attempt RB260GSP CSS106-1G-4P-1S upgrade over POE Port
Fri Apr 21, 2017 6:50 am
I've now successfully updated this RB260GSP CSS106-1G-4P-1S over a non-POE port. The fault seems to occur when attempting an upgrade when access to the switch is via a POE powered-on port. In our case, this makes remote upgrades of these switches impossible.
becs
Fri Apr 21, 2017 10:56 am
gharris999, we will work on to improve it to make upgrade also possible through devices which use CSS106-1G-4P-1S PoE-out.
crtg
Fri Apr 21, 2017 11:51 am
Yesterday we have tried to upgrade few CSS326 from v2.0 to v2.1 but were not able to do so. The switches are not connected to the internet so we did the manual upgrade. After reboot the software version remained the same. Do I need the internet connection to upgrade to v2.1? Thanks.
frankie
Sat Apr 22, 2017 8:39 pm
No. I've updated to 2.1, downgraded to 2.0 and again updated to 2.1 CSS326 without problem from Web GUI (Upgrade menu). Device automatically rebooted with upgraded/downgraded version.
Users browsing this forum: No registered users and 36 guests
