Hello. We've found a VERY CRITICAL failure on CRS326-24G-2S+
It happens with differents CRS326 and also with different SFP+ module (isn't a hardware failure)
SFP+ module: Ubiquiti UF-MM-10G (either in slot 1 or slot 2)
Software version: SwOS 2.4
Configuration: None (out of the box)
When you connect the fiber to any 10gbps equipment, it reboots ad infinitum (we've tried CCR1072, CCR1016-12S and HP Proliant with x520 card).
https://youtu.be/q8Bpq0LGWKI
SwOS 2.0p: Works "without problem"
RouterOS (any version): Works "without problem"
SwOS 2.4: Boot loop
It was working "fine" with SwOS, but when we upgraded it, all ports went down.
900km and 10 hours to replace it with TP-Link switch.
Thanks MikroTik
