MUM Europe 2020
metricmoose
Cannot Change Password on V2.5 on CSS106
Fri Sep 22, 2017 6:57 pm
I upgraded a CSS106-1G-4P-1S to SwOS 2.5 and it will not let me change the admin password. The default password is blank, so I leave the "Old Password" box blank and enter the new password in the "New Password" and "Confirm Password" boxes, though I get an "ERROR: Incorrect old password" message and the password is not changed. Is this a bug? I did a factory reset and I was still unable to change the password.
pcunite
Re: Cannot Change Password on V2.5 on CSS106
Fri Sep 22, 2017 7:28 pm
That's sound strange. Are you able to do a netinstall? This will reformat the drive and all settings.
Slon
Mon Sep 25, 2017 4:37 pm
I have that same problem. New switch, new soft 2.5. Any idea?
metricmoose
Mon Sep 25, 2017 5:10 pm
Well, I found a workaround. I had SwOS 2.1 for the CSS106 downloaded to my computer, so I downgraded to that (Using the upgrade tab), changed the password and then upgraded to SwOS 2.5. Kind of a pain, but it works.
colanderman
Thu Sep 28, 2017 7:20 am
Confirmed, same problem here on a brand-new CSS106/RB260GSP.
tonmt
Fri Sep 29, 2017 11:06 am
CRS326 on SwOS too.
jea
Sun Oct 01, 2017 12:18 am
just select the "old password" box and enter a carriage return.
Then enter your new passwd and confirm.
That worked for me.
plankanater
Mon Oct 02, 2017 5:01 pm
So it seems to learn the password when you change it.
Because changing the password makes you put in the old password.
But you are able to log in without a password.
mwier
Thu Oct 05, 2017 5:23 pm
I also can confirm the same problem here on a new CSS106/RB260GSP. It is not possible to enter a blank password in the "Old Password" box.
plankanater
Mon Oct 09, 2017 4:05 am
Mikrotik knows about the issue. I opened a support ticket and their answer is to downgrade. If that is their answer I stunned as to why they have not pulled the 2.5 firmware file.
josst
Mon Oct 09, 2017 11:24 pm
Same problem here. After upgrade to 2.5 same issue with password. Does anyone have some idea how to solve it instead of downgrade SwOS? If downgrade is only option where I can find 2.4 version because I don't see it on Mikrotik download pages. Thanks in advance.
gammy69er
Wed Oct 11, 2017 2:04 am
https://download2.mikrotik.com/swos2/cs ... 1s-2.4.bin
I tend to just copy the link to the Current version and adjust the version number to the one I need...
This Link worked form Me to get 2.4.
Users browsing this forum: No registered users and 4 guests
