0ldman
Firmware upgrade
Sat Mar 10, 2018 8:09 am
I missed the last several updates apparently.
Is it okay to upgrade from 1.17 to 2.7 directly?
k6ccc
Long time Member
Long time Member
Re: Firmware upgrade
Wed Mar 14, 2018 9:27 pm
EXACTLY which switch? Most likely the answer is no. At least for some of the switches, the 2.x firmware goes with newer hardware and is not compatible. For example, I have two RB260GS switches. One is the "classic" RB260GS and the other is the newer CSS106-5G-1S. They look the same until you read the fine print on the label. The classic switch takes 1.x firmware and the new one takes 2.x firmware.
RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Warning: I know enough to be dangerous...
Jim
Users browsing this forum: No registered users and 4 guests
