ognjen
SwOS or RouterOS
Sat Sep 15, 2018 9:56 am
Hello everyone,
I have 25+ mirkotik routers and switches with RouterOS. Before v6.41 i configure switch with Master port but now use Bridge.
When start write here I looked SwOS :shock: I have never heard of it!
To test SwOS I use CRS326-24G-2S+ but nothing is interesting.Can't make a scripts, add users, torch, grafic, login via mac, don't see cpu use..
Why Network Administrators need to switch from RouterOS to SwOS? Can someone tell me what is better in SwOS?
Thanks in advance!
Be careful with MikroTik Firewall because you can cut the line [yourself - MikroTik] :shock:
k6ccc
Re: SwOS or RouterOS
Sat Sep 15, 2018 10:33 am
I have two CSS326, one CRS326, one CSS106, and one RB260 that are all running SwitchOS, in addition to three RB750 routers running RouterOS. My general philosophy is that if you want a switch, buy a switch and run a switch OS. If you want a router, buy a router and run a router OS. I don’t mix the two. My routers are used exclusively as routers and the switches of course operate exclusively as managed switches with multiple VLANs.
If what you are trying to do is run a managed switch, SwOS works just fine for my purposes. And buying the switches is less expensive than buying the router version.
I want to write more, but I’ve got to get to sleep...
Sent from a $&@#% iPhone using Tapatalk
RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Jim
ognjen
Mon Sep 17, 2018 11:36 am
@k6ccc
Ty for answer!
I will check SwOS how working but I still think RoutrOS is better :D
indnti
Tue Oct 02, 2018 10:53 pm
IMHO SWOS is faster
Users browsing this forum: No registered users and 4 guests
