thegoop
SwOS on a CRS-125
Tue Jan 08, 2019 8:20 pm
I am going to be moving all Layer-3 off of my CRS-125 and using it as a pure switch. I see the states indicate full line speed switching across ports when used as a switch vs. bridged. Can I run SwOS on a CRS-125 (I don't see an image for it in the d/l section), and if not, how can I ensure it is in switch mode across all ports?
elbob2002
Re: SwOS on a CRS-125
Tue Jan 08, 2019 10:56 pm
SwOS isn't available for the CRS125.
To ensure it's in switch mode simply create a single bridge and have all ports (interfaces) as members of that bridge.
edit - I forgot mention you need to be running 6.41 or higher I think for that to work.
thegoop
Tue Jan 08, 2019 11:12 pm
thanks - we are on the latest ( 6.43.8 ) so that shouldn't be a problem.
So you are saying that all I have to really do to move the CRS125 to be a hw-switch (right now, it is acting as a super simple AP router) is to move ether1 (WAN) into the main bridge (where all other interfaces are)?
Better yet, if I want to run it purely as a managed switch AND NOTHING ELSE, I should just revert to factory defaults and use QuickSet "WISP AP" with mode = Bridge?
elbob2002
Wed Jan 09, 2019 7:53 am
A reset should do it for you. Quickset as WISP AP and make sure Bridge All LAN Ports is ticked.
thegoop
Wed Jan 09, 2019 4:21 pm
Thanks! Do you know if this configuration on the CRS125 will hw offload switching for the wlan1 wireless interface?
elbob2002
Wed Jan 09, 2019 8:52 pm
I'm open to correction on this but I'm pretty sure there is no hardware offload for the wlan interface.
At least not on mine:
# INTERFACE BRIDGE HW PVID PRIORITY PATH-COST INTERNAL-PATH-COST HORIZON
0 H ether1 LAB yes 1 0x80 10 10 none
1 I H ether2 LAB yes 1 0x80 10 10 none
2 I H ether3 LAB yes 1 0x80 10 10 none
3 I H ether4 LAB yes 1 0x80 10 10 none
4 I H ether5 LAB yes 1 0x80 10 10 none
5 I H ether6 LAB yes 1 0x80 10 10 none
6 I H ether7 LAB yes 1 0x80 10 10 none
7 I H ether8 LAB yes 1 0x80 10 10 none
8 I H ether9 DEVNET yes 1 0x80 10 10 none
9 I H ether10 DEVNET yes 1 0x80 10 10 none
10 I H ether11 DEVNET yes 1 0x80 10 10 none
11 I H ether12 DEVNET yes 1 0x80 10 10 none
12 I H ether13 DEVNET yes 1 0x80 10 10 none
13 I H ether14 DEVNET yes 1 0x80 10 10 none
14 H ether15 DEVNET yes 1 0x80 10 10 none
15 I H ether16 DEVNET yes 1 0x80 10 10 none
16 I H ether17 CORENET yes 1 0x80 10 10 none
17 I H ether18 CORENET yes 1 0x80 10 10 none
18 I H ether19 CORENET yes 1 0x80 10 10 none
19 I H ether20 CORENET yes 1 0x80 10 10 none
20 I H ether21 CORENET yes 1 0x80 10 10 none
21 I H ether22 CORENET yes 1 0x80 10 10 none
22 I H ether23 CORENET yes 1 0x80 10 10 none
23 I H ether24 CORENET yes 1 0x80 10 10 none
24 I wlan1 DEVNET 1 0x80 10 10 none
25 H sfp1 CORENET yes 1 0x80 10 10 none
eddieb
Wed Jan 09, 2019 8:54 pm
as the wifi interface is NOT on the same switch-chip as the eth ports, wifi will never have hardware-accelleration.
wifi will allways pass thru the cpu and is limited by the cpu performance
Running 6.44 (stable) on :
CCR1009-8G-1S (2x ipsec/l2tp site-to-site, dhcpd), CRS125-24G-1S, RB1100, RB962UiGS-5HacT2HnT (10pc),
RB951, RB750GL ,RB2011UAS-RM, CHR running dude (CHR running in VirtualBox on OSX)
Users browsing this forum: No registered users and 1 guest
