keefus
Reinstall Switch OS
Mon Feb 04, 2019 5:56 pm
Tried Reinstall of Swos on CRS326 via https://wiki.mikrotik.com/wiki/SwOS/CSS ... _Reinstall and doesnt work I've tried with the .bin and also the .npk which file do I need to use? when I boot up to Router-Os it works fine just no swos.
keefus
Re: Reinstall Switch OS
Wed Feb 06, 2019 2:03 pm
Can anyone help with this?
mtrimarchi
Tue Feb 19, 2019 7:47 pm
I think that there is something strange with CRS326.
When you try to reset SwitchOS (factory reset) it will reboot and starts up with RouterOS instead of SwOS.
If you then change boot option and select again SwOS it starts up but no reset has been performed.
This is a big problem. I've made a mistake on SwOS configuration and I cannot enter anymore into the webgui and in this situation I cannot perform any reset of the SwOS conf.
Kurlec
Wed Mar 13, 2019 7:27 pm
Let me help you guys,
Upgrade the SWOS (if Possible) to v2.9 then reset the switch, after it boots into RouterOS, upgrade the RouterOS to v6.44 and also the Routerboot Firmware to 6.44
After that is done, in RouterOS, open terminal and type the following
swos reset-config
or
system swos reset-config
after that, boot the switch back to SWOS and the SWOS will be resetted.
Hope this was helpful
Users browsing this forum: No registered users and 43 guests
