chrysmon
CRS317 traffic problem
Sat Mar 23, 2019 10:41 am
I have a new CRS317 with the last SwOS. Connecting different other switches on SFP+ ports all the traffic is OK. The problem is with an WiFi access point: when connected through the CRS317 there is no HTTP(S) traffic to internet, while there is some traffic, such ping. I tried to modify the MTU on the router card where the WiFi access point connects (through the CRS317) but no success. Of course when there is no CRS317 to connect the router with the access point, all the traffic is normal.
Anybody please some advice to resolve this?
chrysmon
Re: CRS317 traffic problem
Mon Mar 25, 2019 9:52 am
It's obvious a MTU problem of the switch, different sizes of ping pass, also sometimes HTTP packets, but never HTTPS. I changed the MTU of the router interface but after the switch let through smaller packets, and so on. Is there any way to change MTU in SwOS?
mkx
Mon Mar 25, 2019 10:47 am
Switch never changes MTU as it can't fragment L3 (IP) packets. You have to deal with MTU on IP devices (end devices, router). MTU settings on various devices in same L2 domain (IP subnet) have to match.
chrysmon
Mon Mar 25, 2019 10:54 am
Thank you. Can you explain why on CSS326 with the same firmware and settings all work as expected, while the CRS317 stops some packets?
mkx
Mon Mar 25, 2019 11:38 am
I can't explain the difference when all the rest of config is identical (i.e. without changing anything on any other device, just by replacing CRS317 with CSS326, things start to work).
chrysmon
Mon Mar 25, 2019 3:36 pm
I would like to downgrade the firmware from the actual 2.9, can you please tell me where to find older one(s)?
chrysmon
Mon Mar 25, 2019 11:13 pm
Finally I booted RouterOS, upgraded to last stable, setup in bridge mode, setup VLANs and the same wireless access point works normally, there is data traffic. Of course first I tested without any VLAN settings and worked. So no hardware problem, most probably SwOS bug.
Please someone confirm that in bridge mode there is full speed, 10GB on all 16 SPF+ ports.
Thanks to all, still waiting for SwOS to work.
SpaceCompany
Thu May 02, 2019 9:13 am
Any vlan tagging enabled which might conflict?
Verstuurd vanaf mijn SM-G965F met Tapatalk
Users browsing this forum: No registered users and 10 guests
