beermix
Remotely reboot router on SWOS
Wed Aug 07, 2019 1:52 pm
Hi all!
Perhaps you have encountered the problem of remote rebooting the router?
I want to configure a reboot of the router once a week. But it doesn't have a scheduler (unfortunately i can't unplug socket physically).
How i can do that?
EdPa
Re: Remotely reboot router on SWOS
Fri Aug 09, 2019 8:57 am
Unfortunately, this is not possible through SwOS. In case you are using a dual-boot device (any CRS3xx series switch), you could easily set up scheduler in RouterOS.
victorsoares
Fri Aug 09, 2019 4:31 pm
My solution for this was to set the alarm systems that I have on my remote switches to be able to turn the electrical plugs on or off. That way I can set routines on the alarm or just do it from my mobile phone, plus, I can monitor current and all other sort of things in the environment, such as A/C temperature.
MTCNA MTCRE
beermix
Fri Aug 09, 2019 4:54 pm
Perhaps we are read by representatives of Mikrotik. Will there be support for ssh access in SWOS?
pe1chl
Fri Aug 09, 2019 4:58 pm
I think not. SWOS is very limited, and it needs to be that way otherwise it would become ROUTEROS.
machack
Fri Aug 09, 2019 11:42 pm
i hope in SWOS v3 get access from SSH and fix all problems!
Cesar Javier Robles
www.WindNet.com.ar
MTCNA - MTCTCE - MTCRE - MTCWE
Users browsing this forum: No registered users and 6 guests
