anav
Firmware Version Changes to 2.0p
Mon Oct 21, 2019 4:05 pm
Manually Upgraded to 2.10 last week and it upgraded and now states version 2.0p, which is not 2.10???
newer 260gs model.
What the heck is 2.0p ?????
I tried manually loading 2.10 again but still stuck on 2.0p?
Afraid to upgrade my other unit from 2.9
Any advice welcome.
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
Kevo
Re: Firmware Version Changes to 2.0p
Mon Nov 04, 2019 1:07 am
I had the same thing happen on one of our switches. Loaded the upgrade through the web interface and when the switch rebooted it had downgraded to 2.0p which I think was the factory installed firmware perhaps. I did the upgrade again through the web interface and after it rebooted it did come up with the 2.10 firmware. It seems to be fine after this, so I think it's OK to just run the upgrade again. I'm not sure if there was some other piece of firmware that needed to get upgraded first before it could accept the newer release or if it was just a glitch with the update code in my previous firmware, but it didn't seem to have any issues upgrading from the 2.0p version.
anav
Wed Nov 06, 2019 4:30 pm
Thanks Kevo I tried like 5 times with no luck. Just afraid to brick the switch.
i will try again today, maybe the 260GS likes my electrons today.... finicky POS.
Users browsing this forum: No registered users and 2 guests
