AJIOB
CRS326-24G-2S+ (SwOS) static LAG configuration bug
Tue Nov 05, 2019 8:00 pm
Hello.
I want to configure multiple static LAG trunks on one switch and have problems with its configuration.
I have 2 static LAG channels with other switches.
But when I manually set channels to different groups, they go to one trunk group (you can see in on LAG tab.png file).
When it set, I cannot ping any other network devices, that located behind any of that LAGs.
But if I manually set one of the LAGs in passive mode & manually disable one cable from newly passive LAG, all is working.
What need I do to have 2 hardware static LAGs on that device?
All required configuration screens (as I think) were attached.
With regards,
Alex
Users browsing this forum: No registered users and 44 guests
