TheWitness
SwOS and Digest Authorization
Sat Jan 25, 2020 11:37 pm
The SwOS has some real good stats that can be delivered over a Digest Authorization with URI, but in testing, I'm having issue getting the Digest Authorization to work. Are there any requirements we should know about, for example, any requirements (say for example on the length and format of the cnonce) that MikroTik can provide to make it a bit easier?
Thanks,
TheWitness
TheWitness
Re: SwOS and Digest Authorization
Sun Jan 26, 2020 12:42 am
The beauty of using CURL, is that you don't have to figure too much out. Okay, I'm getting stats now. Just to parse is all. I can figure that much out.
blingblouw
Sun Jan 26, 2020 8:59 am
How are you actually consuming this? What endpoints are you hitting?
davidand
Fri Oct 09, 2020 11:13 am
@TheWitness,
Can you please share details about how did you managed to make it working?
I'm trying to do the same but my CURL commands hit 401 Unauthorized, it seems like every request need to have it's own authorization UUID.
Thanks.
Users browsing this forum: msimmons and 5 guests
