beckzg
VLAN problem
Sun Feb 09, 2020 10:29 am
Dear team,
we have tens of Mikrotik switches (RB260GS, CSS326-24G-2S+RM and CSS326-24G-2S+RM) and now we wanted to setup VLANs, but after two days we are still unsuccessfull. Followed the instructions: https://wiki.mikrotik.com/wiki/SWOS/CSS326-VLAN-Example.
Currently I minimized the config, I choosed one port, assigned to VLAN 100 and made the port VLAN mode to Strict. But still I can reach the port from any other ports as you can see in the screenshoots, ping works.
Kind Regards,
Zoltan
mkx
Re: VLAN problem
Sun Feb 09, 2020 12:26 pm
What if the port in question is made only member of VLAN100? Settings of the rest of ports are not exact so it could be that (lack of) settings of the rest of ports interferes ...
BR,
Metod
k6ccc
Long time Member
Long time Member
Re: VLAN problem
Mon Mar 02, 2020 5:55 am
You gave us so little information that it is hard to help. For example, you showed that some pings worked - but no information on what was being pinged or from where. If you are allowing only untagged traffic on the test port, why are you allowing more than one LAN on that port?
RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Warning: I know enough to be dangerous...
Jim
Users browsing this forum: konst and 7 guests
