So my base network is just VLAN ID 1 which is untagged then I have 4 more tagged VLAN's. I am powering this 326 from the UniFi switch using passive POE so ports 1 & 2 are connected to the UniFi.
On the LAG page setting I have port 1 & 2 set to 'static' and Group = 1
On the VLAN page I have port 1 & 2 set to VLAN mode 'Enabled', VLAN receive 'any' and Default VLAN ID '1'
On the VLANS page I have entered all my VLANs inc number 1 and set which ports can have access to them so port 1 & 2 both have boxes checked for all VLANs
Soon as I then set the UniFi switch to 'Aggregate' over the 2 ports that connect to port 1 & 2 on the 326 I lose network to the 326 (ping fails) and cannot get back on the 326 interface until I change the UniFi back to 'Switching' for the ports, I have tried a bunch of other configurations on the 326 and just getting nowhere, really need to get this working or the 326 will need to get returned otherwise
Anyone able to help or point me in right direction?
