incertia
SwOS VLAN untagging behavior
Thu Mar 12, 2020 9:31 am
What is the effect of "Default VLAN ID" if the port is set to "only tagged"? Will egress packets on that VLAN ID still carry the same tag or will it be dropped?
It also seems as if "only untagged" will still allow connection from the port. e.g. switch IP is 192.168.1.3, allow only from vlan id 1, only on port 24. port24 is configured to enabled, only untagged, default vlan id 1. pinging from vlan id 1 yields some ping results but does not actually perform switching, as other pinging other switch 192.168.1.4 does not produce a reply, likely because vlan id 1 is stripped on egress from 1.3 switch.
anav
Re: SwOS VLAN untagging behavior
Thu Mar 12, 2020 6:30 pm
Default VLANID works in conjuction with other settings and by itself is benign.
For example if a packet arrives at a port, there are certain settings that will assign the default vlanid tag if there is not another existing tag. etc...........
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
Users browsing this forum: No registered users and 9 guests
