rcmpayne
Can CRS305 with swOS allow you to set sfp port specifically to 2.5g
Sun May 10, 2020 8:11 pm
Hey folks,
On the crs305 with swOS, can I get a sfp port specifically to 2.5g? The wiki talks about it but does not say if it can be set specifically to 2.5g.
Specify speed setting of the port
https://wiki.mikrotik.com/wiki/SwOS/CRS3xx
Link to product
https://mikrotik.com/product/crs305_1g_4s_in
Shukin
Re: Can CRS305 with swOS allow you to set sfp port specifically to 2.5g
Wed May 20, 2020 6:34 pm
I have the same question. I have several USB adapters that support 2.5 Gig. This would be a nice increase to the speed for things like vMotion in my home lab. The CRS305 running Router OS seemed to support 2.5 gig but I can't get a link using the same NIC on the switch running swOS
Does anyone have some insight?
aruffell
Tue Jul 07, 2020 9:23 pm
I have the same question, however in my case I do get a link.
I upgraded my NAS with a 5G USB based ethernet NIC. When connected to the CRS305, SwOS reports the link as 10G, while the NAS reports its link as 5G. Shouldn't the CRS305 be reporting 5G?
Also, I am only getting about 500Mbits of throughput. If I connect the NAS to a 1Gbit switch, I get the full 900 Mbits. So, even though there is a link, something is off.
mada3k
Wed Jul 08, 2020 12:46 pm
I would not expect to much from a USB based Ethernet adaptor, maybe if it's USB-C/Lightning-based.
CCR/CRS/hEX/wAP • Ansible • NetXMS
mbovenka
Wed Jul 08, 2020 1:53 pm
My CRS309 running RouterOS reports 5Gbs:
status: link-ok
auto-negotiation: done
rate: 5Gbps
This with a QNAP USB3 5G adapter on the other end. I assume you connect the same adapter to the gigabit switch? If not, are you sure your NAS has USB3 ports?
Users browsing this forum: No registered users and 9 guests
