dcol
RTSP usage
Mon Sep 28, 2020 7:18 pm
I started researching RSTP and my head practically exploded. I have a simple setup using SWoS. Using the CRS309-1G-8S+IN for SFP+ connectivity. I have the Ethernet port connected to an unmanaged switch which connects all my 1G devices and the firewall/router. I am not doing any bridging as I see it. Should I just disable RSTP or doesn't it matter?
I assume that the only time you need to use RSTP on a port is when it is attached to another level 2 switch. Is that correct?
biomesh
Long time Member
Long time Member
Re: RTSP usage
Mon Sep 28, 2020 9:43 pm
It is beneficial if you need redundant links between switches or to detect loops on the network. If neither of those apply to you - you can disable it.
DarkNate
Re: RTSP usage
Mon Sep 28, 2020 11:09 pm
There's no harm in leaving it enabled, it simply protects your network from looping.
Users browsing this forum: No registered users and 36 guests
