koffeiniker
SwOS boots but cannot access
Sat Oct 31, 2020 1:43 am
Hi!
Got a new CRS317, bootet RouterOS, went to 192.168.88.1, switch the Boot to SwOS, bootet.
At this point I lose the Switch: no response on neither 192.168.88.1 nor 192.168.88.2.
I tried to be smart and connected the serial console. I got into a menu, tried an awful lot of resets ... no effect.
What is striking me, is that it reports an IP-address of 0.0.0.0 when booting SwOS. In some post I have seen it should be the expected 192.168.88.1
I can happily switch back to RouterOS which works as expected, but there is no way to have SwOS boot and be available at 192.168.88.something.
I would expect it to report on boot and listen to 192.168.88.1 (or 2). But all I get is 0.0.0.0 in the boot status.
In some post I saw someone using the boot primary SwOS option (p). I believe I tried this once, but since then that menu item is gone.
The system reports to boot a SwOS 2.10p, but only on the console, no way to make it answer on the network.
I access the switch via its Gbit port. Directly from a notebook with nothing active in between. I am pretty sure that the notebook itself is properly configured for 192.168.88.0/24 as it works nicely when RouterOS is on.
I should point out that for now ... nothing else is on the switch. I was just trying to bring it to SwOS before connecting any further devices.
Any clue? Any hint? ... Help! :-(
k6ccc
Long time Member
Long time Member
Re: SwOS boots but cannot access
Sun Nov 01, 2020 3:47 am
Can you hook up the switch to something that will provide a DHCP address (usually your router). Then look at the DHCP server to see what address was assigned. Then try to go to that address.with a web browser.
RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Warning: I know enough to be dangerous...
Jim
dazza
Sun Dec 27, 2020 4:28 am
i am having the same problem, did you get it worked out? what was the solution? i have tried allsorts and attaching to a dhcp server has no affect.
Users browsing this forum: No registered users and 7 guests
