norepto
CSS610-8G-2S+IN SFP+ Management acces problem from trunk SFP1+
Wed Nov 11, 2020 2:12 pm
Hi all,
I did the conf like that:
SFP1+ Trunk (VLAN69)
Eth1 Trunk (VLAN69)
Eth8 Acces (VLAN69)
When the CSS is connected by the port eth1 to another swith (trunk) everything works fine. I can acces to management from the acces port eth8 and from outside by the trunk port.. When the CSS is connected using the SFP1+ i can not acces to the management of the switch from outside. In both scenarios from the port eth8 i can acces to the rest of the vlan69.
I have even tried to use a SFP to copper in the SFP+ to connect direct with my computer using the VLAN tag 69 in my network card without results. Aswell i had try to connect using the SFP to copper in the same port od the main switch what was working using the eth1 of the CSS. Any sugestion?
nagylzs
Re: CSS610-8G-2S+IN SFP+ Management acces problem from trunk SFP1+
Wed Nov 11, 2020 2:20 pm
Next time you create a new thread, please check if somebody has already posted something similar. The SwOS topic is currently full of CSS610 problems:
viewtopic.php?f=17&t=167952
viewtopic.php?f=17&t=168159
viewtopic.php?f=17&t=167049
viewtopic.php?f=17&t=168475
etc - they are multiplying like bunnies.
nagylzs
Wed Nov 11, 2020 2:21 pm
Users browsing this forum: No registered users and 5 guests
