folkert
Management DHCP Client on GPEN21
Fri Dec 04, 2020 2:13 pm
Hi, today I received a GPEN21 testunit. We want to use it as a fiber to copper converter.
All looks promising but i cannot get the unit to do dhcp request for management on a specific vlan (7). If it boots it does dhcp request untagged.
Is there a way to force swos to use vlan 7 while optaining an IP address with DHCP? We cannot do untagged in the FTTH infrastructure.
folkert
Re: Management DHCP Client on GPEN21
Thu Dec 10, 2020 3:07 pm
Got answer from mikrotik support:
Thank you for contacting MikroTik Support.
We have observed the same behavior in our labs, and we are looking forward to fixing it in upcoming SwOS versions.
Currently, I can only suggest using a static IP address configuration.
Best regards,
Users browsing this forum: No registered users and 5 guests
