alexk1
CSS610-8G-2S+ Not passing DHCP request to trunk
Tue Jan 26, 2021 3:15 pm
Hoping somebody can help I have a CSS610-8G-2S+ that wont pass dhcp requests on VLAN1 along trunk to core switch. I have used packet capture and have confirmed that the switch does broadcast to other VLAN1 ports but not over the trunk. Other VLANs DHCP pass fine on the trunk. Anybody any ideas please?
Thanks in advance,
Alex
ropeguru
Re: CSS610-8G-2S+ Not passing DHCP request to trunk
Tue Jan 26, 2021 4:11 pm
Can you give us a few more details about each port and what is supposed to be traversing them? Like are some suppose to be access ports with a single untagged vlan vs. which are tagged trunk ports?
I would update the config on the VLAN tab and set the "VLAN mode" and "VLAN receive" in accordance as to how each port is being used.
For example:
Trunk - VLAN Mode: strict, VLAN Receive: Only tagged, Default VLAN: whatever you want, Force VLAN ID: unchecked
Access port: VLAN Mode: strict, VLAN Receive: Only untagged, Default VLAN: appropriate vlan, Force VLAN ID: checked
alexk1
Tue Jan 26, 2021 4:39 pm
Thanks for the question so this switch in a build/test area where we configure new devices before installation. Ports Gi7&8 and Te1&2 are trunk ports to core switch, esxi host, wireless AP. Ports Gi1-6 are access ports and are assigned to whatever vlan is needed at the time.
I will try the settings you mentioned and report back, I just find it strange that this only happens on VLAN 1, all others work fine?
Thank you for your time
Alex
alexk1
Tue Jan 26, 2021 4:58 pm
Tried the settings and unfortunately it doesn't make any difference.
Alex
jookraw
Tue Jan 26, 2021 5:08 pm
which SwOS version you have? in the out of box version I had lots of issues with vlans and dhcp, the switch seemed to ignore any vlan config and strip the tag on each frame received.
try to upgrade it to at least the 2.13rc5 on this thread: viewtopic.php?f=17&t=167891
EDIT: I had huge packet loss when using the latest 2.13rc12 on the SFP+ ports
alexk1
Tue Jan 26, 2021 5:47 pm
Hi Jookraw,
Sorry should have said am using 2.13rc12, sorry to hear about your packet loss I dont seem to be experiencing any on mine? have you tried different optics?
Alex
jookraw
Tue Jan 26, 2021 11:38 pm
I'm using Mikrotik's BaseT 10G SFP+, and I don't have packet drop issues on other versions.
I remember having DHCP issues on the same client but thought that was the packet drop that was causing it...
nannou9
Wed Jan 27, 2021 12:45 am
Why are you forcing vlan id?
Also you don’t want to force vlan id 1 as this id is kinda special.
I have same switch and got it working well with multiple vlans, trunk ports, access ports etc. My trunk is on sfp+.
Vlans are working for me on all 2.13rc5+
There are already threads for css610 vlans where support team gives more details how this should be configured.
alexk1
Wed Jan 27, 2021 12:07 pm
Hi Nannou,
Thank you for your post both here and on other CSS610 threads,
From other threads the below seems to be the recommendation:
As for the VLANs, I would suggest trying these settings:
- Disable the "Add Information Option" under the System menu
- For access or untagged ports, use "VLAN Mode = optional", "VLAN Receive = only untagged" and specify the "Default VLAN ID".
- For the trunk or tagged ports, use "VLAN Mode = strict", "VLAN Receive = only tagged".
- Make sure to include all the necessary member ports for each VLAN ID under the VLANs menu.
When I first went to RC12 these were the settings i set, unfortunately they still give me the same result that DHCP broadcasts are not passed on the trunk if they are on VLAN 1.
Alex
EdPa
Thu Jan 28, 2021 3:38 pm
Does it work when you add the VLAN 1 entry in the "VLANs" page? From the configuration on your first post, the VLAN 1 seems to be missing.
alexk1
Thu Jan 28, 2021 7:20 pm
Thank you EdPa,
I will be back with the switch on Sunday and will try then, I had thought that VLAN 1 was on by default. Will post results here once tested.
Alex
nannou9
Thu Jan 28, 2021 9:09 pm
Sorry had no access to my machine and was answering from my mobile previously.
Attaching screenshots of my working config on 2.13rc12
eth 1 is my trunk from my router which serves multiple subnets and services for my vlans (DNS, DHCP etc).
Sfp+ are my trunks to other switches - so strict and only tagged.
eth 2-8 access ports, so they are marked as optional/only untagged. Default vlan is used to tag untagged traffic on ports.
For eth1 and sfp all marked as strict and only tagged, default vlan id is ignored as all packets are tagged already as per strict/only tagged config.
I do not have force vlan id anywhere as you can see, which only makes sense for tagged traffic if you want to retag packets with different vlan id. For untagged traffic it makes no difference if force is selected or not.
GL mate
alexk1
Tue Feb 02, 2021 1:15 pm
Update: Resolved
Following EdPa's suggestion above I rebuilt the config from factory reset and added VLAN 1 manually and can now see DHCP requests on VLAN1 on the trunk.
Thank you all, and fingers crossed we get a proper release soon!
Alex
ectoplasmosis
Thu Feb 04, 2021 6:12 pm
I'm running 2.13rc12 on a CSS610, trunked via SFP+1 to a CRS317 at 10GbE via a DAC.
VLANs are configured and working on the 1Gb copper ports; I get correct DHCP addresses when plugging a client in.
But when I plug a client into SFP+2, regardless of how I have VLANs set up, the CSS610 will not pass traffic to SFP+2, and the copper ports also stop working properly until I re-plug SFP+1 trunk.
What is happening here? It would be great to be able to use the second SFP+ port for a 10Gb-capable client.
alexk1
Fri Feb 05, 2021 11:29 am
Hi ectoplasmosis,
Have you raised a case with support? the more people have problems with the CSS610 the more resources will be put to fixing it. Can you show us your two VLAN tabs from the webgui? Have you disabled "Add Information Option" under System / DHCP & PPPoE Snooping?
Alex
ectoplasmosis
Fri Feb 05, 2021 1:17 pm
Hi, thanks for the reply.
I've attached screenshots of the config; SFP+1 is configured as a trunk port passing VLANs 1-10 from a CRS317, and all copper ports and SFP+2 are configured as access ports, each with a different PVID.
As mentioned, with this config, all copper access ports work OK, but if I plug a client into SFP+2, the switch becomes unresponsive... Almost as if there is a loop somewhere, even though SFP+2 is configured identically to the copper ports.
alexk1
Fri Feb 05, 2021 3:17 pm
I would start on the VLANs tab by un-assigning vlans 1&9 from the ports that don't need them (I.E. VLAN 1 only select port 1 and SFP1. VLAN9 only select SFP1 and SFP2)
Also why are you blocking access to all ports other than SFP1 for SFP2? (Port Isolation tab?)
Below is what is fully working for me:
Alex
alexk1
Fri Feb 05, 2021 5:11 pm
I currently have 4 trunk ports on 7,8,SFP1,SFP2 and ports 1-6 I assign as needed. I did previously have a client(access port) on SFP2 working fine(same as what you are trying to achieve) and i had just removed the extra VLANs on SFP2 and assigned a native VLAN ID on the VLAN tab.
ectoplasmosis
Mon Feb 08, 2021 8:12 pm
Thanks for the tips; I'll try this.
Mikrotik Support also replied with a new firmware version, 2.13rc25: https://box.mikrotik.com/f/a4b001debcee4a05aec2/?dl=1
alexk1
Mon Feb 08, 2021 9:28 pm
Good luck and thanks for the update!
ectoplasmosis
Tue Feb 09, 2021 2:56 pm
Just to confirm, 2.13rc25 has fixed my issue with using a client via SFP+2 access port. It now works as expected.
Unfortunately, it now breaks the 'IGMP' tab in the web interface; instead of listing multicast member table, it now just has "ERROR: SyntaxError: Unexpected token ')'" in red text.
ropeguru
Thu Feb 11, 2021 5:09 pm
And this development is still in complete stealth mode with NO transparency!!!
This is the LAST Mikrotik device I will ever purchase..
ectoplasmosis
Thu Feb 11, 2021 5:30 pm
Update:
Using the second SFP+ port as an access port for a client is broken again. Even with everything set as per the copper access ports, the client connected to SFP+ will not get DHCP or pass traffic.
The strange thing is that in the 'Stats' tab, Rx Rate always shows zero when a client is connected to the secondary SFP+ port, whereas Tx Rate and Tx Bytes count up.
pwnet
Tue Feb 16, 2021 5:48 am
I am also having trouble getting DHCP traffic passed on VLANs with CSS610-8G-2S. I created a separate thread on it before seeing this one. I've been fiddling with it for 4 hours now and am convinced it has to be a bug. VLANs behave exactly like I would expect them to....except DHCP. The switch seems to be dropping DHCP....somewhere. I'm unable to catch it with wireshark.
If I assign the devices on the VLANs a static IP, it all works great.
Using version 2.12.2.
It should be noted, that replacing the CSS610 with another managed switch (different brand) or with a dumb switch, all works as intended. Its a lab setup, so I have lots of leeway to change things around. This seems to be a swOS issue.
pwnet
Tue Feb 16, 2021 6:06 am
Further update. Upgraded the switch to 2.13RC25 and everything works as expected now. Seems the DCHP bug was in 2.12.
Users browsing this forum: No registered users and 7 guests
