eben
RB250GS Manual
Sun Jun 27, 2010 11:53 pm
Is there any place that I can download a manual for the RB250GS?
I'm interested in getting one to try, but need to know the basics, like can I get SNMP data per ethernet port, how the VLANs work, etc.
roc-noc.com
Forum Veteran
Forum Veteran
Re: RB250GS Manual
Mon Jun 28, 2010 4:04 am
I don't think you will need a manual. Configuration is pretty intuitive.
The default IP is 192.168.88.1
Just connect to it with a web browser and go through the menus.
There is an SNMP option and a statistics menu with lots of port details so I will assume that you can access these statistics through snmp.
Maybe Normis will confirm that when he returns from holiday.
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
eben
Re: RB250GS Manual
Mon Jun 28, 2010 9:24 am
Tom,
Do you have any?
If so, have you snmpwalked them?
Alternately, what SNMP details appear in Dude?
Eben
staslabs
Re: RB250GS Manual
Mon Sep 27, 2010 11:14 pm
Realy, where is manual?
fewi
Re: RB250GS Manual
Mon Sep 27, 2010 11:19 pm
On the wiki, where the manuals for all other products are.
http://wiki.mikrotik.com/wiki/SwOS
dma24hs
Re: RB250GS Manual
Mon Aug 07, 2017 2:46 pm
My problem is that it does not pass the Vlan by the switch RB250GS
"BY GOOGLE TRANSLATOR"
Janevski
Re: RB250GS Manual
Sat Aug 26, 2017 8:06 pm
Usually when i don't know the OIDs i snmpwalk the whole MIB. You can also print the interface counters OIDs from the interfaces menu.
Users browsing this forum: No registered users and 2 guests
